Use mvpn-isid to dynamically create a VRF on one of the reserved Layer 3 VSN VLANs. The dynamically created VRF, l3vsn-<I-SID number>, obtains the I-SID number from the mvpn-isid command. You can use the ip spb-multicast enable command on that VLAN without configuring an IP address.
If you are using a DvR leaf instance, the VRF name is l3vsn-<l3isid>.Procedure
Enable SPB Multicast for a VLAN:
Switch:1>enable Switch:1#config terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#interface vlan 10 Switch:1(config-if)#mvpn-isid 100 Switch:1(config-if)#ip igmp routed-spb-querier-addr 192.0.2.1 Switch:1(config-if)#ip spb-multicast enable
Switch:1#show ip igmp interface vrf l3vsn-100
                                       Igmp Interface - VRF l3vsn-100
       QUERY              OPER            QUERY   WRONG              LASTMEM                     SCOPE
IF     INTVL STATUS VERS. VERS QUERIER    MAXRSPT QUERY JOINS ROBUST QUERY   MODE       L2ISID   ISID
V10    125   inact  2     2    0.0.0.0    100     0     0     2      10      routed-spb 0        100
The following table defines parameters
                for the mvpn-isid
                    command.
The following table defines parameters for the ip igmp
                routed-spb-querier-addr command.| Variable | Definition |
| <0-15999999>[0-511] | Specifies the I-SID. The MAC offset value is optional. Note: Use
                                            mvpn-isid
                                            0 to enable spb-multicast for a VLAN in the
                                        Global Routing Table.  |
| {A.B.C.D} | The SPB querier address. The default is 0.0.0.0. |
